Granny charger sockets
Apologies, I wasn’t very clear. I meant the clamp entry, where the granny cable goes into the socket enclosure
No need to Apologise!
The cables on those granny chargers are pretty thick! I thought they would have allowed for that!
Out of curiosity I tried mine in an out side socket in my Green house and it fitted without problems. It successfully closed.
You can just get EV faceplates, could you use one with a suitable weatherproof socket enclosure? Or do you need the other bits that some of the dedicated ones come with?
It would give you more options on the enclosure to get.
Thanks for your reply. I’m struggling to find a suitable enclosure unfortunately. Do you mind sharing where your enclosure was from?
I was afraid you would ask that! There are no markings on it so I can't verify the make.
It was more of a test to see if a standard outside socket would take a granny charger lead and it did.
If you are really stuck I can take it off tomorrow and see if there is any markings inside.
Does the cable really not fit in the BG one? It is a snug fit but the socket did close and inspecting the cable entry it did seem adequate to take the cable ie I wasn't concerned it would damage the cable. So I assumed they should all be ok and especially one supposed to be used by a granny charger!
Click Essentials AO501AG unfurnished 1G enclosure (or, if you can't get hold of one of those, AO035AG 1G exterior socket), coupled with a Hager Sollysta WMS81 unswitched 1G socket, which Hager have issued a Manufactuer's Declaration for to say it "Conforms to BS 1363-2:2016+A1:2018 /EV". The 3 holes of the unswitched socket are central (unlike the switched version) so the chunky flex at the bottom of the granny charger plug lines up nicely with the rubber moulded bit. The switch just adds an extra point of failure anyway.
Edit to add pictures:
I don't mean to preach, but bear in mind that a proper Mode 3 EVSE is always a better solution. I've only granny charged my EV a handful of times. I certainly wouldn't tolerate Mode 1 or Mode 2 charging in my own property.
Thanks again. I think a big part of the issue with the BG one was that with it being switched, the pins are offset, meaning the cable doesn’t go straight through the clip. I think I might have to explore an unstitched compliant socket as someone has suggested
I totally get this, but I charge at work regularly and would only be used on the off chance I can’t get charged there. It’s a hybrid I drive with a fairly small battery.
Thank you for this, I think I’ll explore this option. Much appreciated.
I never thought about it, my double socket on my shed takes my son's granny charger, it is only outside socket from a type A RCBO bidirectional so never tried any other outside socket.
Never looked at the make, looks the same as the others, which are BG.
