polo1
Ok guys, hoping you can tell me what I've missed......
Hager 10 way board, all 30ma type B rcbos. I installed the board about 13 months ago. Customer advises that ring final (covers both ground and first floor, excluding the kitchen) is tripping intermittently over the past four weeks, but thinks it's happened as she has been switching off a switched fused spur serving under unit flories in the kitchen. But, the kitchen is on it's own hybrid circuit (ring final off a cooker radial).
I have been unable to reproduce the fault.
TNCS supply, good Ze; both circuits IR fine, no linked neutrals; connections in the board are all in the correct rcbos and tight; switched fused spur (no neon) serving under unit lights checked - all connections good, switch feels fine; ramp tested rcbos - 24ma on both. Tested four Class 1 lamps on the ground/first floor RFC - all fine (one did have a Phillips cfl which I changed for a standard lamp, just in case). Nothing else of particular note on this RFC.
I'm struggling to think of anything else. The SFS in the kitchen could be a red herring, but the customer is fairly on the ball so I don't want to rule it out completely.
So, am I missing something (other than a crystal ball!)?
Regards.
You have a lollipop ring then Polo?
Have you changed the spur?
Have you thought about swapping over the RCBOs and see what happens?
Have you checked for High Protective Conductor Currents?
How many lights are under the counter ? Reason I ask if cheap enough fit some new ones?
Why is there so many lamps on a RFC?
check incomers. tails to CU, etc. could be after 13 months, one of the connections has become a tad loose.
Thanks guys.
- only computer is a laptop and not always plugged in
- incomers, isolator and board tails all checked and good
- with all that's normally plugged in and on and with the under unit florries on, I was getting 7-8ma for the whole installation.
- four table lamps.....not excessive.
- I haven't changed the SFS or the flories, yet!
- I haven't swopped the rcbos yet as the cu is in a small cupboard under the stairs and about 6 inches above floor level - I had a sore back for weeks after I installed that!
Today's was a quick visit to see if I could get a quick fix. The customer is now away 'till Thursday when I said I would go back. I will change out the SFS at that point. There are four under unit flories - will look at changing if necessary. But why a problem on one circuit tripping another???
And yes Malc, a lollipop!:yes:
Des - adjacent.
Try ramp and trip time testing the RCBOs to see if they are a bit twitchy and may be going easily and a transient induced current from an adjacent circuit may be enough to cause it to trip.
Long shot Polo, but try doing a Phase to CPC IR test on that flouro light circuit on the highest voltage setting your MFT will allow (1kV preferably).
Switching off flouros can cause a whacking spike if you pick the right point in the cycle, and if a CPC or earthed case is near enough to a live conductor in a fitting or JB then that might be enough to cause an arc. I once had this problem on an under cabinet flouro circuit and each time it happened it also welded the switch contacts together and cost me a new 3-gang MK switchplate! :mad:
