J
james 14
im at a house that has a domestic fire alarm with mains wired smokes and co2 detectors. client wants a heat recovery system 2 shut off wen alarm sounds so was thinking off using a contactor to knock it off. the interconnect cable of the smokes has to kick in the contactor but its not 230 volts. would could i use
You can change smoke to Aico and use their relay interface will give you 5A to control a contactor. Their radio gear would make life a liitle easier.
You don't want it to energise the contactor when the alarms sound but the opposite you want it so when the alarm sounds it will cause the contactor to de-energise.
unless you wire the contactor as N/C, then energising it will disable the load.
