the first thing here is to measure the ambient temp where cable and fittings will be when stove is on, then from there id design the install, and Fin170 i get what you say regarding the gu10's but you need to remember the lamp has to dissipate its heat away and if ambient temps are too high you will effect the lamp life.
As the O/P is saying they will be low level under the stove its possible this wont be an issue as the heat dissipating from the stove will rise pulling in airflow from the room but as i said just getting a temp reading gives a good start point to this design.
