Discuss Heated seats question help in the Auto Electrician Forum area at ElectriciansForums.net
Dm100
Hi everyone hopefully someone can help. I've ought a 2011 rav4 with heated seats as standard. They are controlled by an on off switch but must be timer controlled as well because when turned on they heat up cool down for awhile and heat up again. If I bought an aftermarket heated seat kit could I install the kit but use the original pads so i don't have to take the seats apart. My hope is to have variable constant heated seats
might not be a timer. could be a stat. turning them off if they start to get too hot.
It may also be that your vehicle is fitted with a smart alternator/ battery saver too. If your vehicle is demanding too much power the ecu will shut down or minimize power to ensure the battery retains it's reserve charge for essential systems. I am not familiar with the system on yours so I may be wrong.
As @telectrix has said it is almost certain to have a stat of some sort or it would just overheat to the point of discomfort or damage.
Thanks for the replies. If I take a new feed from the fuse box, and wire in new switches and wiring harness to the original seat pads should i get constant heat or will the pads work the same way as they do now? I don' want to go through the hassle of replacing the pads but I don' want to burn my bum either LOL
By the time you are frying your ar5e the cabin heaters should be warm enough to heat the car I think the Rav4 cuts the power to the elements when they reach a certain temp to stop the elements from burning out.
Reply to Heated seats question help in the Auto Electrician Forum area at ElectriciansForums.net
Hi auto-leckies, This is a DIY query. I have no electrician qualifications but I have electrical literacy, my original trades were heavy (HF)...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi Everyone, hoping someone will be able to help me decipher the wiring for this hoist controller. the handset it came with has stopped working...
K
My central heating is working fine and if I demand water, then I get a small supply of hot water within an hour. The problem is my water does not...
5K
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
