R
RogertheBodger
Hi Guys and Gals.
Working in a large garden today, lots of lighting, several sets of ground mounted 1W Led's,not installed by me but all worked good for a couple of years to my certain knowledge.
Today, one set of six are not working, they are all wired back individually to a central point where they are supplied by a 3-38v 350mA driver. disconnected the output side and tested it - 0 volts, OK fine.
fitted working driver from another set, output from this driver is 39v DC but lights still not working sounds to me like all six are goosed, can't see one volt over the driver rating being enough to take them all out?
Sooooo, cause? .................... I'm imagining the gardener hitting a cable run, dead shorting it, and the spike has gone through the driver somehow and out to the lights, overloading them, can't say I know a lot about Led's, spent an hour looking at this on the net and they don't seem to be the type of lights that take what current they need, rather the type that only work on the current they're given and as such can be easily overloaded, can't understand why all six should go at the same time, so any thoughts, as always, gratefully received.
