HELP PLZ?! Earth trip faulty? Puzzled. Crisis here + 2 full fridgefreezers 3 days no power!
Is my earth trip faulty?
The crcuit breaker never trips.
Why do all circuits cause earth trips with low load ? PC monitor ok but not 45" led tv & 30A circuit cooker circuit & up/down sockets same.
Earth reset rejects to latch but eventually latch on any circuit. can trip again if any small addition (mob. torch charger, small led light)?
We had water leak from wc above kitchen & just a half pint of water each time & I assumed cause but now seems coincidence? I checked sockets & pulled out live & earths - no change.
2 old freebie full fridges without power for 3 days! No micro, aircook,kettle,tv,pc (but went black s=creen with "sector" problem same day? etc.
Can't use my PC & struggling with old laptop without my passwords or email, Google etc.
PLEASE HELP.
THANKS in anticipation.
PLEASE HELP.
is this one RCD doing multiple circuits?
PLEASE HELP.
Since you have had a leak (Is that now fixed?) I suggest you call out an Electrician who can do some IR Testing to make sure that isn't the issue.
A faulty RCD is not out of the question but again the Electrician will also have the equipment to test this.
You will be pretty limited in what you can do yourself without that test equipment.
Hi, Yes, Plz. see pic. Thanks
There is no picture.
The reason I asked is it could be due to cumulative leakage. You said it is putting something additional on that then trips it, but not the same thing but anything additional?
The leak may or may not be coincidental, how do you know it wasn't near any electrics? It was above the Kitchen so would start the investigation there. Most likely the lighting, any ceiling lights that might have been near the leak?
Even if the leak wasn't near a light fitting there could be a junction box in the ceiling that was under the leak.
I take it you have tried unplugging absolutely everything you can and seeing if that makes any difference? Could be an appliance that is causing it.
But I would start with the Kitchen lights these things are rarely coincidental when there has been a leak.
