A
AnthonyDaley
Hi all,
I have a job opportunity awaiting for an insurance company carrying out safety/repair works on flooded houses. They have asked me if i can sign paperwork off ie: minor works/ major works certification. I am unsure of what qualification or certificate i need to be able to do this?
I have only ever worked for one company with whom i served my apprenticeship, i am 22 years old and came out of my time last september. I have my 17th edition but i'm not sure if i would need to be part p or have my 2391 or anything else to be able to sign off my work?
any help would be greatly appreciated! thank you
Hi Anthony and welcome to the forum
Is this going to be self employed/subby/on the books ?
The first thing you would most likely be asked is to test the installation and that would need to have a EICR so you need to perform that. On the ESC site there is a dedicated document associated with flood damage I would recommend you download that and read it with regards to what you need and have to do on the EICR
As for repair work it will depend on what it is. If your replacing damaged cable then you do not need to notify it, even in a special location and so you will not have to in a Part P scheme to do this.
They'll want you to be a member of a CPS, google elecsa, napit, niceic, stroma, bsi. You'll find all the info on what you'll need for membership on their websites and there's also a load of threads on here
I should think i would be part of their team/company. The work they told me i would be carrying out is very basic, such as replacing water damaged sockets, lighting, replacing boards if damaged. am i able to fill out a minor works cert with the knowledge and competance i have?
like for like aint notifyable.....
you would of course need to carry out tests on stuff you replace (like for like)...such as low ohms, IR, loop etc...
Would not class that as minor to be honest
If your on the books then the company will be Part P affiliated and they will have a QS that will sign off on things, unless that is your role
A CU change would entail a full EIC. To be honest Anthony only you can judge if you feel competent enough to sign off work. As a sparks you should be able to sign off All your own work
well, i rang the company back and they said that the majority of my work would be changing sockets and lights, they rarely get rewires or damaged boards but if these works were needed then they would be happy for me to carry it out and them bring someone in to test it. so for the minor works (sockets,lights etc.) do i need anything to complete this cert?
- - - Updated - - -
also i would be the first and only electrician on their books so they are entering new terrain aswell
Son why don't you sit down with these guys and talk to them.
Tell them as your a sparks it would be better if as a company they should apply for Part P accreditation and nominate you their QS while waiting for the assessment you could do the 2394/5 courses and be ready ................... Once you have past the assessment then you can self certify all your own work.
To complete a MEIWC/EIC/EICR all you need a calibrated MFT and COMPETENCE..................... which as a sparks you should have.................Competence
AnthonyDaley,
malcolmsanford,
