F
fourbtwo
I have 4 square d mcb's with no info on them ( been worn away from the front). Can some one help with how I find the ampage of them and the curve type. Believe it or not they have been using them as the switches.
If they are the old black bakalite variety, the curve characteristics can be outa this world!! lol!!
whats the point in this....?..
to the O/P.....sling em.....
1)you don`t know how many faults they`v had to clear in the past...
2)you don`t know the magnetude of fault they`v had to clear.....
3) if old types.....with no info how do you know the max withstand?
well it just goes on....
He doesn't know the rating to be able to get replacements.!!
And that would mean he'd he have to check the cable size and the equipmnet used on that circuit to determine the correct rating, something that could have been done in the time it's taken to post and get answers on here.
Yes yes yes. Got all the comments. Could use the power triangle and cable size to work it all out, but thought some one might have had a quick answer. Sorry for not adding pics, didn't actually think they would help. I do think because they have been used as switches, they have probably had it. Will go back back do the calcs, put in some new ones, and then add switches in the line. Always the way though, thought there was a short cut, only to find I went around the block twice.
Thanks for the help and have a good Christmas all.
