I am installing a nest thermostat on our oil burning furnace to replace the old thermostat and following the instructions by Google for DIY. Our old thermostat has a red and white wire only, and while activating the thermostat on the app, it was indicated that I needed a C-wire through a Nest Power Connector. I had our oil and gas company servicing our furnace and asked them if I had everything needed to install it, and they said we would need a 24 volt / 20 VA transformer to make it work. Please see the attached diagram with instructions for the set up. I picked up a 24 volt doorbell transformer at home depot, and just wanting to ensure this is a straight forward install as indicated (please see pictures) and okay for a novice to approach. I have connected wires before and following the setup is easy, but in recognizing that I don’t know what I don’t know, want to be clear if an electrician is needed. Thank you.
Although the transformer is sized correctly, (24V, 20VA) a doorbell transformer is only designed to work for short periods of time…
It may work perfectly fine, but a specific Nest power supply product will be designed and tested for the purpose.
Thank you for replying to my message and I appreciate the insight about the doorbell transformers designed usage. Unfortunately Google doesn’t produce a transformer for this application as their Nest Power Connector is designed to wire to the C-terminal on the thermostat, which mine does not have. I just purchased this transformer (link below) on amazon which does not specify that it’s solely for doorbells, and there are multiple commenters saying that it worked for their nest thermostat. Any issue with this you could see?:
Amazon.com: PWS-2420 24VAC 20VA Class II Power Supply AC Adapter UL 24V Transformer Plug with terminals : Electronics - https://www.amazon.com/PWS-2420-Supply-Adapter-Transformer-terminals/dp/B06XRJQS25/ref=sr_1_3?adgrpid=1229254356980996&dib=eyJ2IjoiMSJ9.MGO-h0bobXijKX0BISkpPNjaIvKLnM0HmAdGYD4kVApmyXmA4y7zyeKP_AMOLrmtRjfqxd0Jspe6A-13JNhqPDRqX66mjdqRsWeWBPzZfd4lKm04F7V_NJxKO1LzZ_knnggC3PWcltW-r-53-h2F8pYzhwtuxZgdSdFeIIlub9lrN4YHrdBMANhsxpW4DRTSs-JoFmGvSfbyhfzrKb4TQTptOXG0LtvYX8qtJr1mJiE.jMNGkbtMrKlIVKiu-fFoffpnEsvGEbmVFXOkKdstGi8&dib_tag=se&hvadid=76828565912732&hvbmt=bp&hvdev=c&hvlocphy=103576&hvnetw=s&hvqmt=p&hvtargid=kwd-76828675424676%3Aloc-190&hydadcr=3974_13300692&keywords=24vac+transformer+20va&mcid=a89f648a3cea340c8d90a804dd11da23&msclkid=90aba56511f515142537cc5dd65f8f65&qid=1765328823&sr=8-3
