Help with understanding how electrical wiring is working.
We have a small utility room and a new (large) fridge / freezer. Where it has to fit there is the CH /HW controller, a fused spur socket to turn the controller on/off and and second fused spur that turns on / off a low level 3 pin socket which the new appliance will be plugged into.
I need to move these units 60cm sideways so they can still be accessed with the new appliance in place. I opened both fused spurs and could see load-side connections and supply connections in each socket. I confirmed operation with a meter and a test screwdriver. The issue I have is there is a cable connecting supply to supply between the 2 spurs which I don't understand as each has an independent supply. I took the fused spurs off and confirmed 240volt supply in both boxes and a connecting cable (continuity tested). Any advice gratefully received.
Your wish is my.....
Pictures x 2 above show the spur running the timer with the load wires on the right and the supply and loop connection to the socket spur on the left
Do they both go off with the same circuit breaker?
Moving those sideways will not be straightforward.
It is likely to be a ring final circuit. Moving these points probably isn't a DIY job.
