Deanmillington
Hi I am stuck on a question. it is an example question so it gives you the answer but i dont know how it gave me that answer:
A moving-coil ammeter gives full-scale deflection (f.s.d) at 15 mA. if the instrument resistance is 5 ohms,
calculate the value of shunt required to enable the instrument to read currents up to 3A.
p.d across meter = Ia Ra
= 15 x 10-3 x 5 <------- what does this mean how do i put the sum into a calculator?
= 75 mV
p.d across shunt = 75 mV
what does the 10-3 mean
WOULD IT BE 15/1000 X 5?
CAN SOMEONE EXPLAIN THIS TO ME PLEASE
10-3 means ten to the power of -3 ie 10 times 10 times 10 but it will be negative. your equation therefore is 15 divided by 1000 (0.015) multiplied by 5
Edit there should be a function on your calculator to do this assuming its a scientific calculator
the negative number means the decimal point is moving 3 places to the left
The reason for negative 3 is because the 'ohm' value is in whole ohms wheres as the 'amp' value is in milli-amps, which need converting to whole amps i.e 15mA/1000 = 0.015A. You can see the decimal point has moved back 3 decimal places hence 10 to the power of - 3.
