Discuss holesaw sets in the Electrical Tools and Products area at ElectriciansForums.net
Starrett,are the best, but they are probably the dearest as well, sometimes in the tool section of B&Q they have special deals on, or if not ask in store when and what deals are coming up, they usually will tell you.
Also Screwfix are good prices as well.
Starret are the nuts of holesaws especially if you're using the smaller sizes, but they're not the cheapest (get what you pay for) I've just replaced a 73mm after about 4 years of not constant but fairly thoughtless use ( plasterboard, timber softblock, metal) I wouldn't spend the extra on the starret arbor though I find the B&Q one dead easy to use though not the pilot bits they tend to snap at the slightest bit of not straight pressure
I have got a BOSCH holesaw set.
8 Piece Set. Progressive laser-cut tooth geometry capable of cutting into most plastics, wood and metals, including stainless steel. 8% Cobalt Alloy for longer life.
20, 25, 32, 38, 51, 64mm Bosch progressor holesaws, hex arbor, HSS pilot drill bit and plastic carry case.
I then also brought 2 extra sizes, 70mm & 84mm and managed to still fit them in this little case.
Excellent and very strong.
Reply to holesaw sets in the Electrical Tools and Products area at ElectriciansForums.net
Hi All, I've bought a 12ft Catering Trailer that is mainly fitted with LPG Equipment, but Electrics are required for 1x Undercounter Fridge, 1x...
Hi, I need help with my catering van, I am looking to get leisure batteries for my catering van but don't know how many i need or what i need, i...
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
Hi Guys Time has come where we do actually need to start installing these. Few new builds coming up where is now a requirement. Done the course...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
