Z
zastruja
Hello
I'm a total nub but I have to be cautious with this. I'm probably posting in the wrong sub forum also. Sorry.
So I have this (attached picture, don't know the english word) but with 5 slots.
So it goes into the wall right, now I've got 4 of the slots filled with power cable for the computer, power cable for the monitor, power cable for the speakers and adapter for the router. On the last slot I want to hook up a TV. Will it be OK? I'm scared of possible explosion or something because I have no idea how many stuff can be connected. Please link me to an introduction to this or something :)
Thanks in advance.
should be fine, max power consumption for a pc lets say 500watts, router next to nothing and another 200 watts for a telly.
unless you plug in some 3kw heater you will be ok.
its called an extension lead , have a look on the bottom side, it should have some info about max load it can carry.
Thank you, but what's the limit from the power coming of the wall socket 1000/2000/3000 watts? If I remember correctly my PC's power supply is 650 or 550 watts.
You need to be looking at the fuse board to find that out. Going by your location it will probally be a 16 amp radial circuit. So depending on other loads you should have around 3kW avaiable.
Attached is a picture of my fuse board. What are the different B25 B20 B16? Could it be the amp you are talking about?
Also, the breaker for the socket where my computer is and the tv i plan to connect is the last one, 24, B20.
Also, check your power strip has a CE mark on it and not some chinese crap!
The strip feels like chinese crap to me but it says sweex on the top and theres a CE at the bottom side.
Zdravo zastruja. Kade si vo Makedonija?
Skopje.
Oh, I need one more thing explained, why the hell on my normal sized hair dryer does it say 1100W? That can't be right....
P.S. sorry for messing up the page with this big image :|
The B20 etc is the breaker type and rating. Soit is a 20 amp radial.
You have a hell of alot of breakers there, lol!
If it has a CE mark that it should be safe to use.
1100w divided by EU voltage @ 220 gives you 5 amps. So nothing to worry about there really.
I've managed to realize their use for only about 10 of them :) The other 14 god knows their use. And it's not really a big house barely 60m^2.
One more thing I need explained. In the bedroom there's a heat radiator and it says 2500W. It is connected to a power strip with 2 slots. I turned on both the radiator and the hair dryer so that goes about 3600W. According to the knowledge I gathered and applying my low logical skills, this should have made the circuit breaker to trip because it goes beyond 3000W. But I'm failing somewhere here either in the math which I didn't really do or something else.
This looks probably stupid of me but I'm not ashamed to say what I think and I'm not ashamed to say I don't know and I'm not ashamed to admit a mistake :)
As you stated earlier, it is a 20 amp type B breaker, so I work that out at around 4400 watts. I wouldn't suggest that you try and overload the circuit just to see it 'trip'.
One more thing I need explained. In the bedroom there's a heat radiator and it says 2500W. It is connected to a power strip with 2 slots. I turned on both the radiator and the hair dryer so that goes about 3600W. According to the knowledge I gathered and applying my low logical skills, this should have made the circuit breaker to strip because it goes beyond 3000W. But I'm failing somewhere here either in the math which I didn't really do or something else.
radiator - power consumption 2500 watts, 2500 divided by 220 (voltage in your country) = 11.36 amperes - thats the current that will flow
hairdryer - 5 amperes.
thats something like 16 amperes. it probably wont trip a 16a breaker, it will need some current, how much more depends on charasteristics of your breaker. depends on specs and manufacturers.
Electrical Engineering: Time Current Characteristics for Switching Devices.
try to plug in one more heater, should trip by then, if not may be worth calling a local electrician you may have dodgy old breakers.
zastruja,
zastruja,
