O
oldtimer
Got a phone call from a lady who said can you connect up an electric oven yep I can do that for you got there and she said just got the kitchen done out and the builders "electrician" said when you get your new oven dont get a big one just get a 2.5Kw unit as you do not want to overload the circuit .
So muggins here can see the old oven is connected to a twin socket so I say where is the switch for this o their she says 13 switch fuse outlet fair enough I said so gets the oven done and she said that good now I can work the hob and oven hold on I said where is the hob switch o thats the same as the oven ??????????????? hold on I say move the stuff out the way ther must be a cooker switch for the hob no instead the switch fuse is switching a 7.5Kw hob and wait for it the washing machine as well the oven is on a independant socket So me thinks that there is 6mm behind the switch fuse no not at all it was a spur off the ring so got my amp probe to prove to her that the hob is pulling 30 amps so she says does that mean I have not to use the washing machine at the same time me says errr no it means that you cannot use a 30 amp hob on a 13 amp spur I asked before you got the kitchen retiled and the floor tiled did you not highlight to the builder/electrician that you were putting in a electric hob because I take it there used to be a gas hob with a electric ignition yes she said but it is not a problem he said GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR.
Well I dont do installs I said but the only thing you can do is remove the hob and put a gas one in and I said I just cannot believe a electrician did this plus I know we have been banging on about standards but if it was a spark he must have been a 6 month one. Rant over
I can believe it Oldtimer....Couple of weeks ago I rewired 2 x 7kw hobs in a school D/S room connected to 13a FCU's by a Local authority approved contractor....
