Shaun12
I'm looking to integrate a vsd into a standard auto/stop/start circuit using the drawing below. Currently when the system is in auto an input from a hmi will start the motor. Switched to hand, its the local start/stop buttons. On the power side it would be placed after the isolator/contactor (overload will probably be obsolete).
The drive won't be controlled over the profibus network. I can add terminals/relays. With that in mind would you take a signal from the auto run, start/stop, to control the drive
There will be analog inputs from a pressure switch by the motor/pump to adjust the speed accordingly
