Discuss INTERLOCKED SOCKET 3P+N+E IP67 63A 6h in the Industrial Electrician Talk area at ElectriciansForums.net
can someone tell me if there is a difference between
INTERLOCKED SOCKET 3P+N+E IP67 63A 6h and
INTERLOCKED SOCKET 3P+N+T IP67 63A 6h,
its the T and E thats confusing me as i can not find the socket with a T on it. or is it just a newer version? any help is greatly appreciated
Is it the Type with "T" that you're looking for?
If so have you got a picture of the existing?
(3P+N+T) refers to the pin layout so it must be different to (3P+N+E)
63amp and above can have a short Pilot pin in the centre to switch off the load, but would need the matching plug to work.
It’s not the layout, just the number of pins and their assigned use.
The 6H refers to the rotation of the keyway, which is in the 6 o’clock position for 240/415V connectors
ive looked on the official scame website, and the T is identical to the E socket, but cant find a T socket anywhere on the net at all, so im thinking the E model is just a newer version??
but if they are the same then we should be ok lol, didnt want to shell out all that money for nothing before i checked.
Could be just a typo a T is near the E on a standard keyboard...
I'll get my coat...
Reply to INTERLOCKED SOCKET 3P+N+E IP67 63A 6h in the Industrial Electrician Talk area at ElectriciansForums.net
