Discuss Is there a roofers forum? in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
there was a roofers forum but they all fell off the scaffold.
proper Scousers.
This is a photo from the porch.
I’m not going outside again to take a photo. Still raining
My wife now wants all the tiles off to check the woodwork isn’t rotten underneath.
I’ll have to look out the paperwork regarding a warranty, but would it already have 10 years the same as NHBC?
I would be loathe to do investigatory work of such a nature at this stage. The wood will in no way be rotten any timber in there will be C24 structural grade and treated it would take several years for any rot to appear. I would talk with your insurers about it first and see what advice they offer and whether they would be prepared to meet costs of the leak as you should be insured for that. Clearly some fine detail work has been neglected or it could be the leak was present under the house builders aegis or poor workmanship to put it in common parlance.
I have worked (electrically) on quite a few extensions. In my experience I have often witnessed that when the lintel goes in and the cement is filled in above it they do not wait for it to harden off before removing the acros which causes a fall in the wall above of between 5-10mm. Resulting in major cracks (maybe 3-5mm) appearing across the wall in the structure above the lintel or in your case a falling away of the structure below the bedroom window. This may well have something to do with the leaks you are seeing in your living room. Just an educated guess... It would explain why you are getting more condensation in your bedroom as there is now a greater water ingress from the fall of the wall below your window.
I’ll post other photos when I’m home.
Ok. That’s a scary thought.
I remember the architect had a structural engineer involved to size the RSJ.
Looking at the lead work, it seems sealed against the wall, but there are overlapping sections that don’t have any sealer. I can see if it’s windy, the rain could get in between those layers.
We just want it fixed and not leak anymore.
The lead shouldn't be just sealed against the wall, it should be tucked into a joint between brick courses.
I don’t know how much you can make out here...
The extension is where the front door is and the bay window to the left.
The 2 problem areas are directly under the bedroom window, which is now the middle of a room, and below the en-suite window, which is on the sticky out bit. (That’s an architectural design terminology!)
The whole hip roof there is new, from left to right, under the other bedroom window, above the garage door on the right of front door. There is no leak on this side, but there was no extension other than the roof.
When the lead was put on, they cut upwards at an angle into the wall with a stihlsaw to slip the lead in. They couldn’t do this under the window, as it’s tight... so this is why the roofer thinks that’s where the problem is.
You should be able to see the lead, and the gaps between the strips of lead. That’s where I think the rain is coming in, and should be sealed.
Reply to Is there a roofers forum? in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
Hi all my dad was an electrician and did work on my house in the early 2000s , i had plaster wall lights and am now in the process of redecorating...
👋 First time poster here. My name is Melissa and I’m asking for advice regarding my mom and stepdad’s home. He tried for 4 days to work the...
Hi all, I have been asked to install new electrics to a wooden lodge / chalet. It is a single storey very large building with a flat roof. I have...
