Is this acceptable?
Moley
Supporter
I'm currently rewiring my daughters house. Most of the house is totally bare so no problem there. The kitchen won't be started for a little while due to good old asbestos in the artex on the ceiling. I want to run the cables towards the kitchen so that the rooms can be boarded and plastered while we wait for the asbestos to be sorted. If I run the assorted cables to a box under the stairs I can then connect the new kitchen wiring once the ceiling has been sorted. I was thinking of my industrial background and using a box with DIN rail and terminal blocks like THESE Would that be acceptable?
I've done these 'staggered' rewires many times, having specialised in large house renovations for most of my career, and have often ended up with dozens of coiled up cables parked around the house. Label well and, most importantly, don't skimp on the length of cable in the coil. Plans can and do change, and you don't want to end up with a cable a foot short.
Providing the box is easily accessible and the din rail connectors are of the right size then yep carry on
