Hello!
Hoping for some advice or help please,
Looking for somewhere that sells this chandelier wiring in a minimum 50/100m coil. Here is the link with specs etc:
It's massively expensive for what it is, and when asking if they would supply in bulk, they said no and will only do a 10m coil at £10+ each. When needing the blue and brown cable, it works out more than £200 which is extortionate 😳
I have found this supplier who said they sell this wiring which is similar in 300m coils, which is fine. And it is only a fraction of the cost from this supplier. (£150 for 300m and free shipping) please see below for specs and info 😊
I asked the supplier if this can be used to replace the standard pvc neutral and live wiring normally used within the chandelier arms (not exposed, literally fed inside the Arms) they couldn't answer as they said they did not know enough about rewiring chandeliers etc and the specs needed. So really hoping for any advice and if there's any help with tracking down this "chandelier wiring" for cheaper in a bulk quantity 🙏🙏🙏🙏🙏 or if the wiring above would do the job?
Thank you!!!
(we have a ton of wiring on old lighting and our last electrician really struggled with wiring the Arms and the tights spaces in them, he recommended buying this much smaller chandelier wiring, but kind off want to see if we can get it cheaper or advice) 😊🙏
UK
United Kingdom
Trainee Electrician
Is this wiring OK to use on chandeliers? (UK based)
Thread Tags
Tags Tags
wiring
sillyphilly,
James,
