Dizzy_Maskell
Guys can't see a quick solution to this but I may be missing something ?
The other week every time i turned on the floor lamp my TV and Xbox momentarily flickered off and then straight back on again, No real problem just a bit bizarre.
I unplugged lamp and checked all bits etc and all ok earth appears fine and i put it down to some strange connection issue as it was plugged into the same circuit.
I have now noticed that when the upstairs bathroom light is turned on it causes the same issue, temp loss of power to TV and Xbox only.
I have tried a socket tester in the socket and appear fine even when turning bathroom light off and on
Any ideas as got me stumped
poltergeists.
walk around the house chanting repeatedly " the power of christ compels you" whilst flicking holy water around the place.
are you supplied by over heads. called out to similar problem turned out to them broken .customer said the same thing had been happening to them
We are thinking of selling and moving soon otherwise I would leave it but obviously something wrong with the socket I guess but all seems fine I intend to change it to see if clears the issue but know already it prob won't work as it's only a couple of years old anyway
sounds like a dodgy connection somewhere. could be on the supply.
go outside and jump up and down. see if it has any effect.
Yes I suppose I could check all connections for sockets and look in CU too but like I say it's not that old an install and only on 1 socket outlet just head scratcher when the upstairs lights started doing it.
I did think it may be as load goes on but if oven, kettle etc are turned on it does not happen only the bathroom light upstairs ???????
poltergeists.
Excellent Biff, PMSL
I gave you a thanks for this, for nearly making me choke on my coffee, lol
Just need to clean my keyboard now lol
and which connection usually breaks down under load ?.............
that would be the neutral......
"but where ????" i here you ask........
**** knows lol.
but plugging in your tv & xbox in another room would help rule out the gadgets wouldnt it ?
Yes I'll give that a try too but why just then weird coincidence they both struggle and both in the same socket full on nightmare I think
