Whilst looking to change a light fitting, I found I have a 2-gang light switch with ceiling lights from the lighting circuit, and wall lights from a fused spur off the sockets. Should there be any internal label to note this? I suggested I write the circuit designation on electrical tape on the cables, but someone said you shouldn't put tape in there because it is a fire hazard. Seems unlikely, as rhere is tape everywhere as far as I can see.
No it doesn't need identifying but it should be made clear at the consumer unit.
Label the spur, and note it at the consumer unit.
