Discuss Leak in the Australia area at ElectriciansForums.net
M
mr king
Hi
i am not an electrician but am looking for help. i have bought an old house and asked the electrician to look at the wires he says that the wires are all very old (this is true) and he also says they are leaking???
Q if they are leaking and nothing is pluged in and no lights are on , do i pay for the electricity that is leaking to the ground?
Thank you
no your not paying for anything i suspect he is trying to keep things simple for you
as cables get old the insulation brakes down and the seperation beetween the conductors weakens this could eventually get to a level where (if you have or will have) a trip(rcbo/rcd) your trip switch will go off
Your electrician has probably done insulation resistance tests and the readings are too low (as explained by markspark above) sounds like you may well need a rewire, unfortunately.
As covered in previous reply's,it is highly unlikely that you are consuming electricity unless something is switched on. For peace of mind ensure all appliances including things like water heaters are off,and check your meter readings. If you have the old disc type meter it should be stationary.
I would be more concerned about the general condition of the wiring,following your electricians report.If its the old rubber type and not pvc it will definately be past its sell by date.
Hope that helps.
Reply to Leak in the Australia area at ElectriciansForums.net
I found myself needing to do some emergency plumbing at home this evening. I've got a small guest flat on my property which has been empty for...
A relative recently had an electrical certification done on a rented property. The property was build in 2005 and had previously passed 3...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
