Probably not quite the right title but at the minute there is some surface lighting in a corridor operated by movement sensors which go to full brightness when the sensor is triggered, when no movement is detected they dim down. The lights are an older circular fluorescent type and the sensor inside them says MICRO DIM on it, each light has its own sensor.
The building owner wants to put a grid ceiling in with LED panel lights, what would be the best way of achieving similar with the panels? EM lights are currently just bulkheads screwed to the ceiling. Each light has something like this inside it :-
