M
Mike Blair
led one is
  • power consumption: 80 watts
  • 3x 3W UV LEDs
    anolog i
  • Lamp: SOB 1500W
  • but cant find how much lux they both give off :/
what you guys think i should do i need 2 strobe lights that wont trip circuit breakers that will do small medium events and il be plunging right into the sockets >.< this is painful haha
found an led stobe thtas 6x10w leds? what do you think dave
jeres its specs
  • DMX channels: 2
  • 6 x 10W White Linear LEDs
  • Adjustable flash and intensity rate
  • Flash rate range of 1 - 10 Fps
  • Adjustable hanging bracket
  • 3-pin XLR in/out sockets
  • Analogue remote in/out sockets
  • 3 push button menu with LED display
  • Power consumption: 73W
  • Power supply: AC 240V - 50Hz
  • Dimensions: 378 x 116 x 166mm
  • Weight: 1.8kg
led strobe v analog strobe help
Mike Blair,
Mike Blair,
