LED tape on coving - advice please
sythai
Hi Chaps
Done miles of LED strip over the years in many scenarios, but this one has got me bit !!
Customer's had some coving fitted 'suitable' for LED tape install, square room all 4 walls done.
Its set around 100mm down from ceiling, so we cant actually see when sticking down/ doing it blind as such.
Issue is when powered up it's not a consistent line of light around, a little wavey in places - not looking so nice in my opinion.
Haven't used any profile and it's standard tape not cob.
Profile would a very challenging to fit and would be in sections also/ assuming could have same issue if is mounted slightly off.
Any advice welcome please ?
Thanks Sy
Computer generated image?
I mean, if there;s supposed to be a hidden light source on the flat bit.... where is the shadow on the wall coming from?
If you're trying to stick, say a 12mm wide tape to something wider than 12mm.... you'll never get it straight all the way along if its hidden.
Is it possible to stick the tape to something the same width on the floor...where you can see it.... then drop it in the channel?
