Why am I getting a faint buzzing noise from lighting circuit in just one bedroom, It is not tripping the RCBO the cable is normal temperature. Recently had x6 LED lights fitted and new pull cord for shower extractor fan which is on the lighting circuit.
Any advice appreciated.
where are you hearing the buzzing? is it constant? is it only when certain lights are turned on?
LED lamps can give a noise sometimes... as do fans, or dimmer switches.
The void of a hollow wall or ceiling can amplify the noise so its very noticable.
There may be a faulty unit somewhere which is just starting to fail.
Thanks for the reply. It is in the ceiling of the bedroom a constant low buzz even when the lights are off. Turning of the lighting circuit there is no buzz or humming.
Is there a fan that is constantly running when the circuit is energised?
Could be noise from a transformer above the ceiling, particularly if the shower fan is an SELV type. Manrose, Xpelair, Vent Axia et al provide a transformer 'brick' they suggest can be put in the ceiling void!
If there's a fan isolator, does the noise stop with that off?
Alternatively, as per James, is the fan on permanent trickle setting?
Thanks for the reply - The fan is on a pull switch that is wired into the lighting circuit, going to disconnect fan and see if this stops the buzz noise.
That should test if the fan is creating the buzz by being on 'trickle'.
If the transformer is causing the buzz, and it's permanently connected to the lighting circuit, then, if disconnecting the low voltage side at the fan, the transformer will likely continue to buzz (loose laminations?). I wondered if there was a separate fan isolator switch (not the pull cord) as is often installed, that might disconnect the transformer primary, in which case that should stop the buzz?
