Would you choose Megga MFT1711 or Kewtech KT66DL or other? At the moment only extending existing circuits but looking at registration with CPS so I can change the odd fuse board or install Ev charge point.
I was looking at the Martindale EV 6500 but thought the better names would be, well,better. Thanks for your reply.None,megger x1 crap, got one
You would learn how to make a tester.
Most testers show pramaters.
Like loop testing.
Kewtech same price above
Me ,budget Martindale ev one .
Like loop testing.
Firstly you do not need to be a member of a competent person scheme. If you can prove your qualifications that's all Building control requires. As for a MFT ID GO KEWTECH . one that produces a certificate once all checks are complete i do believe even thier entry level ones do that.Would you choose Megga MFT1711 or Kewtech KT66DL or other? At the moment only extending existing circuits but looking at registration with CPS so I can change the odd fuse board or install Ev charge point.
Kewtech for me also ....solid and reliable MFT KT64 still going strong nearly 2 decades later.Firstly you do not need to be a member of a competent person scheme. If you can prove your qualifications that's all Building control requires. As for a MFT ID GO KEWTECH . one that produces a certificate once all checks are complete i do believe even thier entry level ones do that.
Hi Richy, do you have a model recommendation, new new one is out of my price range. or I seriously nee to put my prices up.Neither. Buy a Metrel tester
