Hi guys, I'm looking to purchase a lux level meter initially for emergency lighting specification but also for a project involving lactive acid, milk production & cows. Apparently if the light levels are perfect then the cows can produce milk with the correct amount of lactive acid so the feed does not need additives which cost. I have installed new LED lights with a dimmer system into a dairy herd & this has already made a massive difference. The problem now is to get the correct lux at the correct height. Any ideas WOULD HELP!!!
Hi Mike , from memory you need a lux level of around at least 160 at eye level when the cow is at rest , and this needs to be maintained for 16 hours a day .
There are differing opinions as to what the maximum lux level should be allowed to rise to for the other 8 hours .
We have so far completed two of these this year , one with just six fittings and the other with something like 70 fittings !
Funnily enough we should have started another one this week , but our cherry picker is still tied up on another site at the moment .
If we do actually get there next week , I will have a look at the specks for the job again and post up more info at the end of the week when I am back home again .
I know this is a bit late adding to this thread, but make sure when you purchase the meter that it is set up for the lighting you want to measure, or ask if it has a correction factor for LED. Some cheaper lux meters are specific to one type of light and the correction for other types can be quite large.
Some of the more expensive lux meters have a setting that will adjust to different light types, however they can be quite costly so if it's a one off job, you may be better of hiring a meter.
I've been using my camera onto a sheet of white paper. It's probably as good as a economy meter and since I always carry it, all I need is the conversion figures which I printed out on a sheet of paper.
Since I only use it to check folks domestic lighting and to help me get my head around what I'm installing and how it compares, accuracy isn't too critical.
See
Conservation physics: Using a camera as a lux meter
