It's not possible to give an accurate answer, it depends what it's fixed into and how well it's fixed.
A fixing into vibrated concrete will have a far higher load rating that if fixed into low density blocks.
A fixing using a plastic plug will have a far lower rating than an expanding metal plug.
If you need an accurate figure, you'll need to do some test fixings and loading in onsite.
