your thoughts on the above topic please were and when is the right time to install maintained or non maintaned emergergy lighting speaking to 6 different electricians and everyone has a different version any experts on emergency lighting would be interested on your thoughts
When its in the spec. :p
Usuallly maintained are used in public buildings for exits and escape routes. Non maintained can be used where people using the building are aware of the escape routes.
I'm sure there is much much more to add to this.
Maintained are used over all fire exits...thus on all the time. All other areas can be non maintained, as they are only required in the event of lighting failure....if the units form part of the lighting, ie the designer has decided that he wants the lighting all the same, then he may choose maintained, so units can have the dual purposed of being switched normal lighting, with emergency backup.
just to add... i'd use LED em's for maintained. them florry tubes won't last 3 months.
Tazz, brilliantly put. Wonder if the muppets who write the regs could copy and paste it!
In areas where lighting can be dimmed (normal public use) such as cinemas/theaters - not just exits but also route lighting should be maintained.
OP - if you need to know this for a job then best consult 5266
In any area, Emergency lighting does not have to be maintained...As I said, emergency lighting only needs activate when supply to normal lighting is lost....Only if a light fitting is being used as a dual purpose switched light and emergency light would it then be maintained.
Example 1...corridor in hotel has 20 normal lights switched, and between every 4 lights there is a non maintained bulk head fitting.
If the light circuit fails, the bulkheads come on....meets 5266 fine.
Example 2....same corridor with 20 normal lights switched. Designer states, he does not want ugly bulk heads in his design.
4 of the existing lights are replaced for matching maintained emergency fittings, to keep with his decor. now all fittings switch on and off in normal use. If the lighting circuit now fails, 4 of fitting will come on....still meets 5266.
Conclusion to this.... its the designers choice
[h=1]Electrician's Guide to Emergency Lighting - IEE book, covers the basics quite a good book. Keeps you check with the Emergency codes of practice.[/h]
