Soulsurfer
612
165
118
Channel Islands
Business Name
M.B.S ELECTRICAL
Hi I am just doing a renovation / upgrade on a small house and as kitchen plus all downstairs was on same ring final I have broken it up into a separate kitchen ring and downstairs ring and renewed best part of the cabling as it was really old stranded earth steel looking junk cable and not giving good test readings. I need to replace the main CU from a 3036 board and a separate garage sub board and also add storage heaters although not as many as client wanted as it was hitting over 90.5A just on store heaters !
I have hassles from DNO as they won't tell me upfront what size the service fuse is without submitting all loads I need to feed, and I need to ask if I have radials for say the garage skts do I apply diversity such as 1st ring final @ 100% and then 40% of all other ring finals and also 40% of radial wired socket outlets ?
There will be a ring in the utility room as there will be 2.5mm feeding sockets for a washing machine and a dryer but I know that the two are rated at 2.2kW ( washing is rated at 2.2-2.6kW ) can I use those figures direct as flc ? and such as upstairs ring may be calculated at 40% but most likely pull less than 5A most of the time.
Thanks...
Its sealed amlu so bit naughty cutting a DNO seal ! I've seen bosses do it a few times before but I'm going to source a 4 pole switch to isolate the tails as and when for future so best not cut their seal before they come out to reconnect the seals on fuse and meter tails cover.
Take diversity with a bit of flexibility, in a small domestic house the load will not be high, just take account of what the storage heaters will be pulling and other likely loads at the time they are on.
The rest of the demand shoudl not be a worry.
If the head is labelled at 60A then use that, if 60/80A then use 60A, if 100A then probably 100A.
Soulsurfer
Channel Islands
Business Name
M.B.S ELECTRICAL
Max demand etc.. on renovation.
Soulsurfer,
Soulsurfer,
