R
ronbrown
Hi all, new to the forum and was hoping for some help. A lighting circuit on my consumer unit started to trip today during the heavy downpour. I went to go switch it back on and after about 5 mins it tripped again. I wonder if it could be water getting into a light somewhere as time of tripping seems to be extending all the time
there is an old outside light that has been terminated in an choc bloc and taped up in a plastic bag tucked under the guttering. No it is not protected by an rcd
well, it's a good starting point.
what would be the best course of action to fix it then? I dont want a light outside as was like this when we moved in. the cable runs through a ceiling with a flat roof above so would be hard to get to it
see where the feed comes from-- light fitting and/or switch, then disconnect.
Make sure you turn the power off!!! And confirm it's off before touching any cables. Especially as it's a lighting circuit there may be a 'borrowed' neutral.
