Spudnik
Hi Chaps,
Going to install a new 10mm shower circuit, however, the CU is the Mem2000 with no RCD protection.
Am i right in thinking i can get a single module RCBO that fits these, which, from what i remember is the MCB & POD set up?
Ta much.
Yes a MEM/EATON memshield 2 MCB with a 30mA RCD pod attached, although the price of them is ridiculous since they brought out their new range.
Well, got the job done with an MCB & pod.
What a bloody silly set up.
Anyhoo, word of warning.
If you try & RCD test it, you cannot do it at the terminals as you would normally.
You have to leave the circuit disconnected, and use two pieces of say, 2.5mm TE connected for the test.
Stick your crocs on the ends and test it that way!
Apparently, just testing the terminals causes the tester to throw a wobbly as they are not the "same" as a normal RCBO.
No wonder you dont find much eaton/mem stuff in domestic.
