Anyone know if there is a conduit strap available in UK market similar to this one:
One Hole EMT Conduit Strap, Steel, 1/2 in. | Garvin Industries - https://www.garvinindustries.com/hanging-and-support/cable-conduit-surface-mount/emt-one-hole-straps/ohs-50
I'm thinking for 20/25mm pvc conduit, I would prefer to use these type of strap because you can put the strap on the pipe, hold it all up with a level on it and screw it straight in, seems faster than using saddles. Also conforms to the requirement of a fireproof strap? Vs a plastic one.
question 2, pvc is conduit sized by O.D. not I.D. right?
