B
Buzz1980
Hi all problem with a Mira shower sport. When the customer uses the shower it starts off fine with flow decent and heat good but cuts off mins later with the low flow light coming on, wait 5/10mins and the shower will come on itself. I’ve checked the power connections all well and good and cracked the in coming pipe and inlet water pressure is good. Anyone any ideas what this issue would be, I’m just thinking would be best to replace the whole unit ? I’m thinking might be issue with the flow valve inside the unit as the water pressure isn’t that great coming out. I have had the shower hose out and pressure not the best. My thinking is it’s not letting the water through as it’s not hot enough ? Any info will be much appreciated
