M
Max Tout
Hi,
I have a spotlight rail with four MR16 bulbs (12v) on it. It has an integrated transformer.
The replacement needs to be of similar size i.e. length approx 90cm and run with low-voltage MR16 bulbs.
There seems to be a plethora of these spotlight rails that use GU10 240v bulbs etc, but I can’t find any that use the low voltage MR16 bulbs.
It’s ages since I fitted one of these. Are the low-voltage rail variants they still available?
Are you looking to replace one of the fittings on the existing rail or the complete ensemble including the rail?
MR16 12v Lighting rail
DIY Electrical Advice
Thread Tags
Max Tout,
Marvo,
