- Reaction score
- 165
Does anyone have any recommendations for blades for my fein Multimaster. I've been using the bosch blades but it breaks my heart when I hit a nail or the likes. Some people say the shark blades are ok but others say they are poop.
Discuss Multimaster blades in the UK Electrical Forum area at ElectriciansForums.net
I brought a load from saxton blades on amazon and for the price cant fault them.
Might give them a whirl. Can't be any worse than the premium blades!!
Done it!! Cheers
Any blade will give poor service if you don't understand the basics of speeds & feeds and that includes drills & hole saws too.
Set the correct speed (RPM) for the material you are working and feed at the appropriate rate (Feet per minute) for said material and you should get decent results.
I use the Shark blades and like them. I believe the biggest problem with all of them is people are under the impression that
the harder you push the quicker the cut. You should let the blade do the work with light pressure, also when cutting through nails and screws use the full width of the blade by moving it back and forth in a gentle cutting motion. Otherwise the stress is on about five teeth and of course it's going to fail. Used with care I get hours of use out of them, saving the blunt ones for block walls.
And how many people would know that a simple twist drill should be sharpened to different angles depending on the material to be drilled?
Reply to Multimaster blades in the UK Electrical Forum area at ElectriciansForums.net
