Discuss Multimeter Help in the Industrial Electricians' Talk area at ElectriciansForums.net
E
eskimo39
Hi guys, I am currently on my 2330 course and am currently applying for work as an electricians mate or labourer. I felt it would be a bigger advantage to own all my own tools so I have bought all the main items inc drills, vde sets, saws etc. However I am now looking at a multimeter to use in both domestic and commercial work and am stuck between 2 different models. Does anyone here have any experience with either and also do you know which would be more pratical? The 2 models are:
  • Fluke 117
  • Fluke T5-1000
Both seem to be around the same price with the 117 only £20 more. I have emailed Fluke for some advice but am yet to get a reply.
Thanks in advance
I use both the t5-1000 and the fluke 73 I could'nt be without either but it depends what you want, I use mine for faultfinding on machinery etc so I would have thought for installation/domestic industrial installs etc the t5-1000 would be perfect for you.
Personally I dont really see much need for you to get a DMM and a good voltage continuity tester is what you should be looking for, the ammeter on the t5-1000 is handy but how much will you use it? if I were you (and you could afford it) apparently there is a special offer from Fluke to get a free voltage/continuity tester with the 1650 series multifunction tester see here
17th Edition Special Offer Pack from Fluke by Fluke (UK) Ltd
I have seen the 1651 for £380 delivered with calib cert so if you can take advantage of the above deal then it may be worth considering
eskimo
rarely get my avo out on commercial work just use voltage and continuity tester .
what type of work you looking at???
You'll be fine with the T5 tester!, does what you need. You might want to consider the fluke 1587 multimeter as it also has the advantage of a insulation tester!.
Hope this helps
I too use the Fluke T5 for basics - Voltage, Continuity, Ampage etc.
I use a Megger 1552 for cert testing and even though I have a multimeter can't remember the last time I got it out?
I also have an old Steinel which I used to use, but now use the T5.
The Fluke T5 is a great bit of kit.
Many thanks for all the responses. I have no experience yet in using a tester as I am currently only in my first year. The kind of work I am passionate about and want to get into once I complete my course is domestic and commercial installation.
I have decided to purchase a T5 which I have found online for £80 to use for basic readings.
However, you have now got me looking at the Fluke 1651.... am I running before I can walk?? I have never used one but am going to be shown how to use one over the next few weeks of my course. I also may have the chance to work for a local electrician a couple of days a week rewiring houses so it could be very useful.
Sorry to be so vague but I really want to give myself the best chance of finding work and have been given a bit of cash by my parents and am thinking of investing it in a good Multimeter to last the time.
Thanks again
The T5 is my day-to-day workhorse. It's pretty indestructible and inexpensive. That's what you need in an every-day meter. Save your fancy, expensive testers for specialized use, and keep them safely tucked away on the truck or at the shop until needed.
Reply to Multimeter Help in the Industrial Electricians' Talk area at ElectriciansForums.net
Saw this on Irish Consumer site (CPCC.ie) HERE Not sure about the rest of the UK but worth checking if you have one. Fluke Europe BV recalls to...
I am seeking a job as an electricians mate / improver / labourer around South Yorkshire. I am based in Doncaster, i have a uk full driving licence...
Hi all, So my factory needs more power, currently 100A/3p (70KVA) => 400A/3p (200KVA) UKPN wont upgrade existing supply and are insisting on new...
So, I got a level 2-3 electrical installation diploma fresh out of college with no experience especially onsite. I was wondering whether working...
i am looking for some help with a decision i need to make. i am having a new kitchen installed but can decide between having 2 3.6kw 16amp ovens...
