Neff B45E42.0GB oven trips the RCCB/Power to house…
Started many months ago when oven set to 180deg,and after a period of time would trip.But when everything was reset the oven would operate for months without a problem,…but then trip again.The temp was then set lower at 170deg, without a problem for a while but started again on occasions.This week however with temp.set at 170deg, and heating up but only showing temp.reached as 160deg the oven trips,but as usual when reset the oven operates normally and cooks the contents ok.After Two days of not using oven ,but switched on third day as usual at 170deg,whilst heating up it has tripped again at 160deg,but as usual after reset it is ok.
The problem is becoming more frequent and inconvenient……
Can anyone offer any suggestions what might be causing these spurious trips?
