Good afternoon all,
I recently had my hot water tank/boiler upgraded to a combi boiler.
A Hive system was installed alongside it, which I love.
My only issue is that the wiring is a little untidy and I would prefer it if the wiring set behind the receiver, as the old one did.
I remove the cover of the hive receiver and saw that there is two sets of cables, one set going to the new boiler and then 2 other cables which come from inside of the wall? What would they be? would they be connected to the fused switch sat next to the receiver?
My main question is, can I route the wiring through the wall and into the receiver at the back so no cables are showing?
Thanks,
Dan
System boilers, normally have motorised valves to select central heating (CH) or domestic hot water (DHW) and often programmers and thermostats control the motorised valves, then the valve tells the boiler to run.
Once DHW is directly controlled by the boiler, the CH can be directly controlled by the thermostat, this is not always the case, sometimes motorised valves are still used to zone the CH, but electronic TRV heads allow the TRV to act as a zone valves, so zone valves no longer needed, as we want analogue control where was can, and the old zone valve is either on or off, and this will not allow a modern boiler to modulate as we want it to, in order to gain latent heat.
But your pictures don't help to work out how your system is configured.
Good afternoon all,
Thanks,
Dan
Yes you can no problem. Looks as though its not been done is because you have tiles on the wall. TBH, if the flex had been cut to a sensible length it wouldn't of look to bad.
Its a combi now so he'll have no valves or configuration to worry about now. Just want his flex looking neater
