Hello - does a DHW secondary circulation pump require its own cable or can it be spurred off from a 1.5mm cable going to an immersion heater?
I've just had a new direct unvented cylinder installed as part of a wider renovation. I might install a secondary circulation pump at a later date, once I've done the bathroom and seen how quickly the hot water comes through. It would only run occasionally, when triggered by a PIR sensor.
I can add a cable now on the off-chance I need a pump, while the ceiling is down, but it's cost and time and may not eventually be required anyway. So I wondered if I could instead, when the time came, just spur off the cable going to the top immersion? If not, I'll just put a separate cable in.
Thank you in advance!
