Discuss Night storage in the Australia area at ElectriciansForums.net
W
Wotsit
I have a customer who would like 2 x 1.7Kw n/s heaters fitted. He is on eco 20/20 and unwilling to switch to a radio teleswitch n/s supply. I have four spare ways in the consumer unit, 2 of witch i would like to use for the heaters. Can anybody reccomend a sutable timer to controll the heaters so they switch on and off inline with the cheap rate of eco 20/20.
Thanks in advance :)
most sangamo clocks will switch 16a resistive load , 1 for each heater but this would work out expensive.
you could feed a 2 way cu off 1 spare way through a small contactor controled by a clock fed off another spare way
Reply to Night storage in the Australia area at ElectriciansForums.net
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi, My husband and I recently moved to the UK and a new flat, after living always in accommodations. We have some big answers about the electrical...
5K
Hello, I’m not an electrician and I have a question in relation to Dimplex Duo300n. Some background information: a couple of months ago I have...
7K
K
I rent out a flat in a small west London block built in 1990s. 2 storage heaters installed around 2005 now have stuck or broken switches so I'm...
4K
