Discuss No offence intended... in the Australia area at ElectriciansForums.net
W
wattsup
But I've had/used a few testers recently, all have worked on jobs of mine.
One asked what size cable to wire a kitchen ring main, ok I thought maybe thinkin, a 4mm radial, can we get away with it? He said washer drier/ kettle / toaster...err nope wire 2-ring mains to kitchen...ok he said.
Thought no more (thinking to myself does this guy know what he is doing)
He wired the rings in 4mm, ok no problem except it cost me more than expected, he said ...I said wire rings in 4mm, err nope I did not. No problem it cost me 40quid more than expected, but hey he couldn't event get the kitchen plan close proximity.
The times checking his work was not cost effective, but guess what part p approved, he was completely hopeless. I need real sparks, housebashing is not complicated
I too have had this problem. I was running 2 housing estates and forever having to drive back n forth correcting peoples cock ups, the final result was whilst on holiday last year the team of guys i was using caused me too loose a job that would have seen me through till the end of 2010.
Where abouts are you? I'll come and do some work for ya! Not done any for a while but house bashing is a piece of cake.
Thats not good Dave, its a lot of lost money and now you have to find more work! Was it new builds?
Reply to No offence intended... in the Australia area at ElectriciansForums.net
  • Locked
5K
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
