Sounds like its the same sort of set up, the controller can prioritise between ON/OFF peak so when the OFF is energised this takes the lead, I would imagine there is a little relay built into the controller to allow this.Hants, looks like it although I only had a quick poke on the inside, I pulled the fuse on the rfc and the boost went off, but there again there is three conductors in the fuse carrier so christ knows
Pict
