polo1
1,285
650
688
Glasgow
Business Name
GW Electrical & Security
Guys/gals, a cast iron three phase head with a PILC incomer, with what appears to be a light brown oil coming from the head down the incomer (soz, no picture as flash would not work). The head is in a domestic property delivering single phase.
Any ideas what the "oil" is and need I be concerned/notify DNO?
Bitumen
And if you've seen it in liquid form, yes the DNO need calling. Not sure on domestic heads, aren't cast iron heads being replaced?
Yes, it is the bitumen leaking out.
The DNO may think it is not bad enough to change, but let them have a look at it to decide.
if its a cast iron head then it definitely needs replacing, and could date back to the 20,s the oil / bitumin thats oozing could be a sign there is a problem , if im not mistaken these fuses were wire, can you get a pic
What they all said
Surely if it looks like oil it's not the bitumen but the cable compound. The paper in PILC cables is impregnated with an oily insulant to prevent it absorbing moisture, and one of the purposes of the bitumen is to keep it in the cable. If you look on the floor of an old switchroom with lots of PI cables you will sometimes see odd splodges of compound. Leakage may or may not be important, now I think about it I don't generally take much notice of a light ooze but a puddle should be reported.
As far as I know, a cast head should be changed.
Depending on the install date the brown oil could be any one of three different things.
Post a photograph.
Thanks guys. I did wonder about bitumen but where I've come across this before it's been black and more of a runny tar consistency. This stuff looks more like dirty 3 in 1. I'm due back Fri or Mon and have now sorted the camera on my phone. So a pic will be taken.
Replacement of CI heads - that's a laugh. We have thousands of these with no programme for routine replacement. The DNO simply will not invest in a replacement programme; hard enough to get them to replace even where there's a fused neutral. Again, thanks for the feedback.
Yeah, get DNO to have a look, might be nothing, if smelling of burning then that is bad, many service heads leak.Too much of the black stuff has been applied.
I've had this before and the dno came and replaced it no problem,also changed it from tns to tncs as the earth was (bare swa rusted out in the street)
No need for the poorly disguised expletives in the public forum ... Im sure you could have made the same point without resorting to this level there are many less offensive ways of saying the same thing and getting your point across just as strong.
polo1
Glasgow
Business Name
"Oil" from cast iron head
polo1,
Darkwood,
