G
GLENNSPARK
when you trunk them finals....the knockouts will be covered....Nope. In through the knockouts in the top with grommets of course. Why?
put several pieces of trunking in...side to side....
you can seperate the finals so..lets say both legs of rings are in one enclosure (trunking)...and so on....
for what you need several ends of trunking...or an offcut you can get 3 stabs out of will cut it....
If you can get all those T&E through grommets while maintaining IP4X/IPXXD, you've done well.
Trunking, as suggested, would sort this anyway![]()
it would just finish it off....Do you REALLY think that's worth all the (chargeable) effort to hid a bit of twin and earth at high level in a rental property? That doesn't even look too bad swept in like that? Hardly 'rough' is it?
I was going to mention maintaining IP4X/IPXXD but guitarist got there first. Could also PVC tube it
out of reach on a domestic?...I yes forgot PVC tube is not suitable for domestic lol silly me! They must be very very large step or ladders for it to be out of reach for me! If its that much out of reach, how do you expect them to safely reset rcbos ? You silly man
I'd have put it on a stand off board while I had the chance, then you wouldn't have to compromise the top of the enclosure.
