When i was an apprentice the firm i worked for did a lot of controls for pharmaceutical company's , and one of its nearest clients (Only about 8 miles from the yard) was Amersham International .
From what i could tell they mostly make radioactive isotopes for medicine and other organisation's .
We had a full body scan to get in / out , your own personal telltale indicator badges and personal digital meters which recorded real time exposure , to much at any onetime and you are off site indefinitely !)
With out getting to detailed they have / had a underground tunnel system in which they use to remove the waste from the labs each week into a building that houses from what i can remember 8-10 eighty or so thousand gallon above ground round storage tanks .
While cable tyeing on to some tray we had just installed in the corner of the building i stepped back and knocked and cracked a 1" plastic pipe and valve that comes of the bottom of one of the tanks which proceeded to soak me , luckily one of the sparks was near and shut the valve down in the end .
I stayed there and he went to raise the alarm ( started to """" myself ) they came for me suited and booted and took me in to one of the quarantine rooms and started waving instruments at me which clicked a """" site more than normal ( proper """"ing me self now !) , in the mean time they apparently shut the site down whilst this was going on and i latter found out from the top man that they had nearly evacuated the part of Amersham that was that side of the site .
It Turned out (or so they said) that they had not been processing the really nasty stuff for while and the waste was more of a bio hazardous nature (body fluids / tissue and stuff like that) than heavy radioactive waste , but they were starting with that again the next week .
They gave me the all clear in the end and told me to """" off home and to come in for a royal b"""""ing tomorrow !
If i get around to it i have couple more story's from that place , that to be honest some what beggar belief .
I am sure others here have worked as subbies in the pharmaceutical industry and know what i am on about .:nonod:
