508pir
Hi ,I’ve been an electrician for 42 years, worked all over the world. Domestic commercial and industrial. Wired up entire factories, units shops etc obviously 3 phase. Just turned 64 so less than 2 years left before pension. I keep getting offered more and more domestic work but as I let my part p lapse during covid I keep turning it down. Haven’t done the 18th to be honest at 64 I can’t be bothered. My question is do I keep on doing what I’m doing now .? What are my options. Can you get someone else to register jobs. Thanks in advance.
You can ask a fellow sparks to sign off your work for part pee but unless they are 3rd party linked then technically they are adopting your work as theirs which again technically you aren't supposed to do
Its a stupid system and well overdue a complete overhaul imo
The requirement is to be competent. Your 'Part P' as you refer to, is just a method of demonstrating that competence.
Most minor domestic work doesn't require anything submitted to building control, but for the jobs that do, try approaching building control in advance, explain your position, an you might find they are satisfied that you are competent.
(I'm 6 years ahead of you, BTW).
If you are doing board changes and full re-wires part pee is pretty much a must Imo
Just factor the scam fee into the cost of the bigger jobs
