Discuss Overcoming joists in the UK Electrical Forum area at ElectriciansForums.net
S
sparrrrk
Hi all,
Hopefully some bright spark can enighten me. Been asked to move a bathroom ceiling light fitting today. Not a difficult job however I can't gain access to ceiling void due to a functional bathroom directly above the bathroom where the work needs doing. Floor tiles are laid which the customer does not want removing.
From where the fitting is now to where it needs to be a joist is in the way. Does anyone know a trick to overcome this from below. Hopefully there's a trick of the trade I haven't come accross yet.
thanks
Bash hole in ceiling
extend cables with choc block
mount light fitting with plasterboard fixings
leave for plasterer to make good
seriously though no easy way. you may drop on lucky but you might not. Id start by making a hole where the new light fitting is going no bigger than what the fitting would hide. Take down the old light and then you should have a pretty good idea which way the joists and cables runs.
MF connectors surely? Daz
From their description on your link: 'A plastic box to insulate connector blocks'
I would say most people would see your phrase 'chock block' in your earlier post and assume you meant screw terminals though. Daz
Talk your customer out of the proposed move, explain the ramifications of trying to drill through a joist you can probably only see one side of, the cost of repairing the ceiling possible damage to cables or pipework on the hidden side of the joist.
find the joist that's in the way. chip out ceiling under joist, 1" hole either side, fish cable, clip to underside of joist, fix 3mm steel plate to protect cable. fill.
Cut 100mm access holes to ceiling with hole saw to either sides of joists, mark the discs you have against the holes so you can get them back in alignment (plaster is not as even as it looks), look at joists and feel them to make sure there are no cables clipped to it or pipes, then get your long spade bit and drill through joist from access hole, feed cable though, get timber batten about 300mm long, place up into 100mm holes, screw through plasterboard ceiling into batten from either side of the circular hole, then hold disc up against batten and screw into batten bridge across hole. Get your easy fill 45 out and get filling.......
They are big enough to get the correct angle on the long spade bit any smaller and you risk drilling diagonally through joist putting your cables too close to the floor above (nails etc), plus you risk the plastered plasterboard discs disintegrating if they are any smaller.
You can try smaller holes but you will probably regret it.
I drive a van FYI.....
i see your method and can't fault it. but i go for smaller holed, don't drill joist but go under it with a steel protector under the cable. however, every job is different and methods vary accordingly.
You could just drill 1 x 100mm or even 75mm hole directly under the joist then cut a small notch for the cable across the underside then screw the plasterboard circle back either side of the notch and fill round the edge.
Just clip it to the underside of the joist where you have bashed a hole in the ceiling, I do it all the time.
I think I'd have put a smiley after that to show that you were joking. Daz
Lol. I generally cut as small a hole I can get away with either side of the joist to get the cable through, clip it tithe underside. I'll be quite honest I don't put anything over the cable, it's RCD protected and in the ceiling, I don't think putting a bit of steel over it is going to make s great deal of difference, I'm not saying I don't do that, it just depends, each job is slightly different.
Pretty much how we do it when needed. Locate joist with a braddle and poke a hole through either side, use multitool and cut a small square out slightly longer than the joist on either side and notch the joist to one side of the square, pull cable through and screw board back and fill.
Edit, refereeing to Davesparks comment regarding Part A, i will certainly be questioning the method described above next time the situation arrises at work.
Your both mistaken, choc block is actually loosely tightend connector strip that creates a high resistant joint which then melts like chocolate:juggle2:
Reply to Overcoming joists in the UK Electrical Forum area at ElectriciansForums.net
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
Hello all, I need to have an electric car charger installed but at the moment I'm puzzled about what my options are. My garage is at the back of...
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
